Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-07-2005, 07:23 PM
jazzycoupe's Avatar
jazzycoupe jazzycoupe is offline
Send a message via AIM to jazzycoupe Send a message via Yahoo to jazzycoupe
Unhappy Transmission Help
Help, Help, Help. I have a 1990 35th Anniv. Supercoupe. v6 3.8 supercharged. Recently, my transmission seems to have died. I cant get my car past into 1st gear from idle without getting vibrations coming from the floor panel. Once I get my car past 1st gear it runs fine, but I dont want to make the problem worse. Any advice? Help!!!
Old 02-08-2005, 02:36 AM
benchtest benchtest is offline
Re: Transmission Help
Need more info. Is this a manual trans.? If so, are you saying it vibrates when you engage the clutch?
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 02-08-2005, 05:22 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Sounds reminiscent of a clutch slave cylinder. But, as stated, which tranny is it?
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 02-08-2005, 04:35 PM
jazzycoupe's Avatar
Thanks for replying. I have an automatic transmission. Sorry if my message was confusing before. When I put the car in drive the car seems to slip a gear, then there is vibration and then the car moves. Once the car moves into a higher gear it seems fine. I was thinking that it might be my differential, or some sort of linkage problem. What do you think?
Old 02-08-2005, 05:07 PM
Check your fluid level when the tranny is normal operating temp. If it's low, it can do what you are describing.
Old 02-08-2005, 07:14 PM
jazzycoupe's Avatar
I'll try! Thanks for the advice.
Old 02-09-2005, 04:23 PM
jazzycoupe's Avatar
(Check your fluid level when the tranny is normal operating temp. If it's low, it can do what you are describing.) - Benchtest
I have tried your suggestion. My fluid is not low and it is also very clean. Any other ideas? Thanks for the help.
Old 02-09-2005, 05:15 PM
How are your motor and tranny mounts? This could also cause it. I am not a tranny expert so when it comes to internal issues, I can't be a big help.
Old 02-10-2005, 08:16 PM
jazzycoupe's Avatar
The mounts all seem normal. Thanks for trying to help.
