Old 02-07-2005, 07:57 PM
purefunchevy purefunchevy is offline
Send a message via AIM to purefunchevy Send a message via Yahoo to purefunchevy
Rim Changes
Does anyone know if the offset from the rims on a 99-02 Silverado 1500 is the same as the offset from a 96 K1500? I am thinking of swapping the rims on my truck to the newer style but I want to make sure they are going to fit. I do know that the lug pattern is the same, 6 lug on a 5.5" pattern. If anyone can be of help it would be greatly appreciated. Thank you in advance.
Old 02-07-2005, 10:19 PM
abaird abaird is offline
Re: Rim Changes
i see a lot of the mid 90s trucks with the newer rims, I think they are the same.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 02-07-2005, 11:47 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Re: Rim Changes
The offset (which is what you initially asked about) might possibly be different on the two different year models, but I still think you will have no problems seeing as how there is alot of wheel well space on trucks. Like abaird, I have seen many mid to late 90's model trucks rollin on newer model stock rims. If you have 6 lug, you could even put Escalade rims on if you wanted I've seen that on older year model trucks
Old 02-08-2005, 11:45 AM
FHBrian FHBrian is offline
I put 04 17" Avalanche rims on my 89 and no problems. They stick out a little further than the stock but not outside the wheel well. I like the look of them. Don't know where you plan on getting them but if you know of a conversion place near you check with them. That is where I bought mine.
Old 02-08-2005, 12:05 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
The 6 lug 5.5 should work. Go to Discount and double check with them.
*Under Construction - New sig to debut*
