Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-07-2005, 06:26 PM
joross422 joross422 is offline
Question Werid Not starting 2500
I have a 1990 GMC 2500 w/350 auto trans. I have already replaced the fuel pump, cap, rotor, wires, and plugs. I will drive about 50 miles and ice fish for about 4 hours, come back and it cranks over and seems not to be getting gas. This has happened three times so far. It also shoots a check engine code for the egr while driving. Once it does start it runs great untill the check engine light comes on and it seems like it really wants to suck gas. The mechanic that replaced the fuel pump said the egr code should not allow the truck to start is this correct??
Any help would be appreciated. Thanks in advance.
Old 02-08-2005, 05:59 AM
Daci Daci is offline
Send a message via MSN to Daci
Re: Werid Not starting 2500
Change the EGR valve, its not expencive at all
Old 02-08-2005, 07:11 PM
Will the EGR not all the truck to start?? Went out to take it toninght and it just truns over and won't start.
Old 02-14-2005, 11:37 AM
BlueMonster's Avatar
BlueMonster BlueMonster is offline
Send a message via ICQ to BlueMonster Send a message via MSN to BlueMonster
Yup. If the EGR valve is stuck wide open, the truck won't start. I had the same problem. I need a quick fix, so I cut a sheet of aluminum and made a little plate to block the EGR valve off until I could get another one. As soon as I did that it started right up and worked like that no problem for 6 months. I burned a bit more gas though. And it's definitely bad for emissions without the EGR valve working.
Old 02-14-2005, 03:30 PM
I did replace the EGR, I ended up taking it to the shop and they put in a module. I picked up an egr and replaced it, It starts pretty good but the check engine still comes on and will probably get that code checked next. Thanks for the help.
