Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 02-07-2005, 05:59 PM
jimnviv jimnviv is offline
Question 97 Dakota electrical problem
I was in the process of replacing the stereo with a newer model. After wiring the quick connects per the manufacturers instuctions, there was no sound. I removed the radio, checked my wiring for accuracy and connected it again. Now, I have no power to the radio connections. I have also lost power to the interior lighting, map lights, courtesy lights, and the cargo lights.
I have checked & rechecked all the fuses & relays. All check out fine.
I'm running out of ideas on where to look. Any help would be greatly appreciated.
Old 02-08-2005, 12:07 AM
jefro jefro is offline
Re: 97 Dakota electrical problem
Strange thing, I was surfing trying to get an answer for the same excate thing happened to me on my 98 dakota.. But I checked the head light switch and found if I positioned it just right, the dang fm would power on..Strange thing is the switch checks out with the fluke meter... I checked all fuses in the fuse box and under the hood...If anyone has encountered this delemia before I would appreciate any responce to help...baffled at the moment... TIA
Old 02-11-2005, 03:57 AM
hmmmmrmm imagine that....welp changed headlight switch still problems...no the horn hangs up blowing when the ignition switch is turned to off after engine run, have to turn light switch back on to get horn to stop...but Im not holding my breath that there is someone out there that knows what is causing it....l8r
Old 02-11-2005, 04:35 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Did you all make the wire connections yourselves? Chances are, when you were making the ground connection, on most aftermarket wiring harnesses for stereos, there's not connection for the ground, sometimes you have to find a good body ground and run it from there. If not, you could run into the problems that you all are running into; happened to me w/ my '85 Ford, I put a Sony Xplod CD/MP3 player and didn't wire it up correctly, every time I hit the light switch, it'd blow a 15 amp fuse that controlled the instrument light circuit. Eventually, it didn't blow the fuse and blew something else, never did figure out what happened, just heads up for you guys.
Old 02-13-2005, 01:20 PM
Thumbs up Re: 97 Dakota electrical problem
After taking a day or two away from the problem, I went back and started over.
The problem was twofold. The I.O.D fuse was blown,and the wiring instructions that came with the harness were wrong. My truck has the Infinity stereo system and the instructions made no mention of the fact that the wiring for the Infinity system is slightly different. I found the info that I needed at www.scosche.com. Problem solved! Thanks for the replies. This is a great forum for auto enthusiast.
Old 02-24-2005, 06:53 PM
gotrice1 gotrice1 is offline
Re: Re: 97 Dakota electrical problem
Hey, I am having the same problem on my 92 Dakota as your original. No radio power and no dome light. But it was wired fine cause it worked for a couple weeks. Just curious, what is the I.O.D. fuse.
Old 02-27-2005, 01:26 PM
1thunder 1thunder is offline
i o d stands for ignition off draw and shuts radio down and dome lamp and numerous other things mostly used when vehicles were new and being shipped around less battery drain with fuse out
Old 06-10-2005, 05:44 PM
rjsmag rjsmag is offline
I have the same problem. Can you tell me where this fuse is located and if it is in the fuse block, what number it is.
Rich
Old 06-11-2005, 08:57 AM
Re: Re: Re: 97 Dakota electrical problem
Rich
Never mind all. Found it in the fuse box under the hood. It is the 5 amp one. It did not look black like it was blown, but it was and that was the problem. Hope this helps someone else that has the same problem.
Rich
