Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-07-2005, 05:45 PM
Macnkirby Macnkirby is offline
Unhappy 91 V6 Camry Tranny Slipping?
Got a 91 V6 Camry I'm fixing for a friend, though I'm not exactly a master mechanic. Quite suddenly the transmission started slipping and it was very reluctant to go into first, and when it does, it doesn't seem to go in all the way, but the car still moves if you give it enough gas, then it shudders, and pops into second very violently. The gears above first don't seem to behave a reluctantly as the first one. A friend told me to drain the transmission and change the transmission screen filter, refill, and it should loosen up those gears. I did this, which it did need pretty badly, but after running through all of the gears several times it doesn't seem to have made any difference. Should I tell my friend to get a new car, or is there a relatively inexpensive solution to this?
Old 02-11-2005, 06:08 AM
zeek1403 zeek1403 is offline
Does the pan leak oil? I had the problem in my 1989 Camry 4cyl where the transmission was FALLING out and had to be tightened and stuff. Now it shifts fine.
Old 02-11-2005, 08:43 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 91 V6 Camry Tranny Slipping?
If it has high miles on it, like more than 150,000, it's on its last leg; the average life for automatic tranmissions is 150,000 to 200,000 miles; after that, it's time for a rebuild.
Old 02-11-2005, 09:37 AM
I disagree with that on Camrys. I have had many Camrys with over 170k on them w/o needing a rebuild.
Old 02-11-2005, 12:15 PM
calvic calvic is offline
I must agree, I have over 310,000 miles on the original trans!!
1988 Camry LE
4 cyl Auto
335,731
1994 Volvo 940 Turbo
1992 Dodge Cummins Turbo Diesel
2006 Mustang GT
Old 02-11-2005, 06:24 PM
You all have more than likely keep your transmissions well maintained, and that's very good. Toyota, next to older Volvos, have the longest life on their transmissions. But ON AVERAGE ACROSS THE BOARD, transmissions don't last that long. One thing that I forgot to mention in my original post, is make sure that the level is at the proper mark. If not, than that could a very good reason why you have a slipping problem in addition to fluid condition/color.
Old 02-12-2005, 06:09 PM
WickedNYCowboy's Avatar
WickedNYCowboy WickedNYCowboy is offline
Send a message via AIM to WickedNYCowboy Send a message via Yahoo to WickedNYCowboy
It sounds like it may be the TC. Very rarely will it be the tranny but the converter causing the problem with a fluid pressure issue. But when it is as old as it is I'd say rebuild it before it gets any older.
Evan
Support your local volunteer fire department
My Rides:
2003 Ford F-350 Long Horn Hauler
Others:
1999 Toyota Camry LE V6-Dad
2004 Chevy Tahoe Z71-Sister
2004 Toyota Camry LE V6-Mom
