Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 02-07-2005, 05:05 PM
89B2200 89B2200 is offline
Send a message via AIM to 89B2200
89 B2200 temp sensor
They cost about $35.
Are they really this expensive?
This sensor goes to the bottom of the radiator with two wires.
I tested it and it is open, no resistance reading.
I heated it up with a gas lighter and no change.
What is the resistance reading at 35F, 60F and 180F? Any ideas?
Thanks for any reply.
Old 02-09-2005, 08:29 PM
11 views and no replies. C'mon guys, somebody knows about this.
Ok, I only have the Haynes manual and it has no mention about this temp sensor.
Maybe somebody has a Factory Service Manual and can look it up for me.
Is this just a switch, temp dependent resistor, or a thermocouple?
Thanks in advanced.
Old 02-13-2005, 03:05 AM
mazdatech mazdatech is offline
Re: 89 B2200 temp sensor
HMMMMMMM. I will take a look in alldata monday..
Old 02-13-2005, 03:07 AM
but if i had to guess the ecu uses this sensor for emossion control where as the sesor on the thermostat is only used for the gauge onthe dash.
Old 02-13-2005, 05:30 PM
I found a cheaper one at Advanced. $26
I tested it with my fluke meter.
Still confused. New one has neither resitance reading nor millivolt reading.
Not even a switch contact that makes when heated.
I will install it and see what happens.
Old 02-14-2005, 12:32 AM
toplessmazda87 toplessmazda87 is offline
Send a message via MSN to toplessmazda87 Send a message via Yahoo to toplessmazda87
hey i got like 8 mazda pickups partein out i will sell you waht vere you need email me for any parts i got every thing andi mean every lil thng i saved and for sale prices right email me at [email protected]
Old 02-26-2005, 12:21 PM
Finally traced the temp sensor function that is located in the bottom of radiator.
It is not a temp sensor, it is just a cold temp switch.
The switch makes around 55F and opens around 60F.
Tested the switch by dipping in iced water and the switch closed using a digital meter.
This cold temp switch activates the PTC heater in the bottom of the carb to prevent the carb from icing up during cold weather start-ups.
Just for everybody's info.
