| Maintenance problems, fixes. |
Hard to remove the alternator
Hello, guys,
I had problem in my 92 G20 and need to replace the alternator. The battery doesn't get charging voltage at all. However I still cannot remove the old alternator maybe because I missed a bolt. I searched G20 service manual, Chilton's manual and google, but still didn't find the information I needed. My situation now is: I have removed all the bolts visible and driving belt on the alternator, including the tension adjust brackets and the pivotal bolts at the joint of alternator and engine body. Now I can move the alternator up and down a little bit, however still cannot detach it from the engine body. Seems there is something locked it to the linkage joint. Any clue please let me know ! Thanks a lot. Sincerely yours, Xiong Jiang |
Did you ever get it off? If not, I can tell you how I did it.
Yes. I did it after remove the upper coolant hose and joint pipe.
It really took me some time because I was hesitating not to remove the hose and pipe. What's your experience ? If it doesn't take you much time I appreciate you describe it. ![]() Thanks, |
