Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-07-2005, 02:32 PM
D-Bo's Avatar
D-Bo D-Bo is offline
starter
how can you tell when your starter is toast?? does it not work at all or what?? cause mine is now putting out a constant sound.. it sounds like its really trying but its not chugging like it normally does..
geez its so hard to describe things.. i need a sound clip..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 02-07-2005, 05:03 PM
s13dr1fter s13dr1fter is offline
Send a message via AIM to s13dr1fter Send a message via MSN to s13dr1fter
Re: starter
I also got a question about the starter sorry D-bo. But is the starter thing that spins is it suppose to come out and spin?
Old 02-07-2005, 11:49 PM
NiSmO_zt's Avatar
NiSmO_zt NiSmO_zt is offline
Send a message via AIM to NiSmO_zt
Re: starter
the starter is toast if: the battery is fully charged, and when you turn the key, you hear a click, humming, or nothing at all. to be sure, push start teh car (assuming its a manual), if teh car runs fine when push started, the ignition is good, and the alternator should be good, just check the voltage over the next couple hours driving.
if its been really cold there, it might just be frozen up, try putting it in a garage for a bit, or wait for warmer weather.
my current 240--ka-t
Old 02-08-2005, 07:03 AM
Chuki_breath Chuki_breath is offline
Re: starter
yes good info. Does a starter come out and spin? i dont think it does. Sorry how do you push start a manual. I know the hole concept on how it works but forget how. I just got my first manual car so it would be nice to now the correct way. Dont you just like pop clutch or something while its moving while turning the key? I totally forgot how to do it, i watched one of my friends do it years ago to his mustang when it wouldnt start. But have since forgot.
Old 02-08-2005, 10:40 AM
NiSmO_zt's Avatar
Re: starter
lol, yeah, you just put the key in to unlock the ignition, and make sure it is in the on position, then, if your by yourself, pop it in noodle, open the door, and push it wiht one hand on the wheel, the other on the door, until you get about 5 mph, then dukes of hazzard it, jump in, shut the door, clucth in, first gear, drop clutch, and hope it starts, if it bogs and stops, do it again, but faster!
as for s13drifters comment, yes, the solenoid on the starter is made to push the pinion out to engage the flywheel, and then pull back so its not continually running when the car is.
Old 02-08-2005, 03:18 PM
D-Bo's Avatar
Re: starter
its been just above freezing here for the past week so i thought things might be a little more thawed.. maybe my battery is running low.. i'll see what i can do..
Old 02-08-2005, 06:50 PM
Re: starter
o now i see what he means by spinning lol...he made it sound like some super cool mechanism that opens up and does tricks lol.
