Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 02-07-2005, 02:24 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Amp installation help
I just bought a 96 Eclipse GS. What is the best way to run my amp power wire to the battery. I don't see any openings in the firewall.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 02-07-2005, 02:30 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: Amp installation help
There should be a rubber gromet(spelling?) that you can run a power wire through. Thats where mine is. If not you could drill a hole but i dont recommend that unless your sure you wont hit anything.
Pictures of the Truck
Old 02-07-2005, 06:12 PM
Where around is the gromet located?
Old 02-14-2005, 08:38 PM
rs97eclipse1695's Avatar
rs97eclipse1695 rs97eclipse1695 is offline
Send a message via AIM to rs97eclipse1695
uhh...i think mine is ran on the passenger side...pull the carpet back some and look there...not 100%
2008 Eclipse GT
-Sun Sound and Leather Package
-BONE stock
1997 Mitsubishi Eclipse RS
-Cold Air with K&N
-Stainless 4-2-1 Header
-2.5" Catback
http://www.cardomain.com/ride/3012565
Old 02-14-2005, 10:37 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
I have installed quite a few stereos in my life thus far and I am having a hige issue with my car. I have found the so called grommet I believe, however I can not figure out where it comes into the vehicle. If anyone has any pictures that would be amazing, bloody dsms are impossible to work on!!! :-)
thanks
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-14-2005, 10:02 PM
96RSeclipse 96RSeclipse is offline
Send a message via AIM to 96RSeclipse
okay, i have a 96rs and as ghetto and cheap as this sounds, it actually worked quite well. ive installed plenty of amps in past cars and friends cars and ive never ahd a harder time running the power wire than i did in my eclipse. i actually ended up running the wire from the battery down into the fender and along the bottom part of the car then back up under the back seat. like i say, it worked out great for me, no road noise or anything. if you want a more detailed description, let me know and i'll take some pictures and explain more clearly.
"I know your car is fast - You were haulin' ass when i passed you"
1996 RS Eclipse 5-Speed... R.I.P.
Old 03-14-2005, 10:53 PM
im pretty sure mine is going though on the driver side.
Old 03-18-2005, 01:37 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
you can go through the stearing colum boot
DSM geek
Old 03-18-2005, 09:56 AM
bighauns's Avatar
Yeah, I am thinking that on the drivers side it is a lot easier to run, however most people do not want to run a power wire across their car and then all the way back. That is like 5-7 extra feet of wire, which you want to try and keep to a minimum. The more power wire that you have to run through, the more voltage you are going to loose at your amp.
