Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-16-2002, 08:42 PM
Maxima4gen Maxima4gen is offline
Send a message via AIM to Maxima4gen
Unhappy Intake
I Installed A Intake on My 1997 Nissan Maxima. i just took off the box with the filter at first. i drove it around and everything was fine. then i figured all tha rest of the tubing didint do anything. so i took it out and i think i took out another sensor to ..when i started my car the check engine light came on. i put everything back after that and its still on what should i do???????
Thanks
-Anthony
Old 03-17-2002, 12:17 AM
Corion Corion is offline
Send a message via AIM to Corion
ok, you actually did not just take the airbox and the piping off right? you added like a cone filter or something I hope, because taking off your box and filter and running your car is basically like dumping sand into your engine...
Old 03-17-2002, 09:22 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
sensor
if you disconnect the battery and then reconnect, the service engine light should go off
Old 03-18-2002, 09:12 AM
kado200 kado200 is offline
Lightbulb do you know where i can get a cold air intake
do you know where i can get a cold air intake e-mail me at [email protected]
Old 03-18-2002, 01:59 PM
Ravq Ravq is offline
Did you unplug the harness to the Mass Air Flow sensor? That is probably what tripped the MIL light. You can read the codes from the ECU to see what tripped it and then reset it using this:
http://www.seas.ucla.edu/~cheston/images/reset.gif
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
