Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-07-2005, 11:27 AM
ulonggapo ulonggapo is offline
acceleration problem
I've been having engine surging/acceleration problem with my manual 89 240sx. It starts ok, idle is ok, if I step on the gas while parked and in neutral its ok. But when I'm driving and I step on the gas too fast I feel my engine reving/surging and there's no change on the acceleration. Read a lot of similar post so I tried some of the suggestions. This is what I have done so far.
1.) Replaced the BPT valve with OEM BPT
2.) Replace vacuum line connected to BPT
3.) Checked all vacuum lines, none seems to be cracked, kinked, or broken.
4.) Replace fuel filter
5.) Replace spark plugs with NGK
6.) Replace spark plug wires
7.) Clean air intake
8.) Replace air filter
9.) Replace clutch slave cylinder. It was leaking, I thought the clutch was sticking but that didn't help.
10.) Took it to the dealer and told me that the check engine light is not working. I told them that its not going to work because I don't have one. They didn't fixed the problem and I still have to pay $88 just for them to say we don't know what's wrong.
I haven't done anything to the EGR, PCV, and AIV. Can anyone show me where the AIV is. A pic would be great. I have read a lot of thread about how to clean it but I'm not sure where it is exactly.
Thanks
Old 02-07-2005, 01:47 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: acceleration problem
clean out your mafs.. if that doesnt help then you'll need a new one
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 02-07-2005, 02:07 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Your clutch is slipping, get a new one.
Old 02-07-2005, 02:12 PM
D-Bo's Avatar
i think we're picturing two different things.. we need more details about what reaction the car gives when you put your foot on the gas. if the revs go up smoothly when you gas it but you don't accelerate as quickly as it sounds like you should, then yes, logik is right. but if your engine is surging or sputtering and struggling then it sounds like your mafs
Old 02-07-2005, 02:15 PM
logik23's Avatar
Banned
Speaking of slipping clutches, my dad told me to take his Altima to the car wash last night, so obviously 5 minutes later I'm going 150kmh(90mph) on the freeway, the problem was, when I merged onto the highway, I'm flooring it through every gear, but nothing happens since the clutch is finished, was so anoying!!! Couldn't have any fun, but it was still cool...anyways...
Old 02-07-2005, 02:17 PM
D-Bo's Avatar
i drove this 2002 celica gts that had been traded in after a year and the clutch was absolutely toast.. which was too bad cause the gts is a very fun car to drive..
Old 02-07-2005, 07:51 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Describe whats happening better. When you push the gas, do the rpms rise? Or does the car just kinda bog or buck? More input needed.
I'm not sure on the E, but on the DE the AIV is the black box on the drivers side of the engine bay with hoses running from the exhaust manifold to the air filter box. Easy to find. Its right in front of the master cylinder and beside the power steering resovoir.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 02-08-2005, 01:47 PM
I cleaned the mafs with qtips and alcohol and its still the same way. I'll take a look at the AIV next.
When I'm starting from a stop, its ok. Once I'm driving let's say 45mph on 4th gear and I try to push the pedal some more before changing gear, the revolution increases but there's no change on the speed. The tachmeter goes up and I can hear the engine. It doesn't sputter or anything, it sounds like stepping on the gas pedal in neutral. Once I let go of the gas, the RPM goes back to where it should be. It does this on all gears not just on fourth. Although I haven't really pushed hard on 1st gear to notice it. I don't have any problem shifting. As long as I don't push the engine hard (stepping on the gas pedal) It seems to be running ok. hope this helps
Old 02-08-2005, 03:10 PM
logik23's Avatar
Banned
Your clutch is finished, that's the problem, no buts, you need a new clutch.
Old 02-08-2005, 03:35 PM
D-Bo's Avatar
yeah, logik is right.. and you probably have a funky smell going through your car when it happens right??
Old 02-09-2005, 12:15 AM
240SX Guy
Like I said before, its the clutch. Jeez.....
-Cory
12.6@122mph
Old 02-09-2005, 12:49 PM
D-Bo's Avatar
nah, nobody has mentioned this: the clutch.. thats your problem.. i take all credit for that one
haha jk nissanfanatic
Old 02-09-2005, 01:08 PM
drumpet15's Avatar
drumpet15 drumpet15 is offline
OH! It sounds like a cue for me to say "it's the clutch!" Right?! RIGHT?! All I ever do is agree with you guys! It's gotta be the clutch!
(that's for you d-bo)
1985 Nissan 300ZX N/A
Mods:
-rebuilt block and heads-
-K&N FIPK intake-
-KA throttle body-
-NGK plugs and wires-
-Exedy clutch-
-Cusco strut tower bar-
-MSA headers-
-2.5" exhaust w/magnaflow muffler-
Old 02-09-2005, 04:47 PM
blownup240 blownup240 is offline
My 93 fb has a problem too..... if i get on it for a while(few mins) it will die out like its hitting the speed limiter, but it goes all the way down to 2500 rpms then starts bucking very violently... the maf looks clean and the harness isnt cut any where so i dont know whats up..... anyone else have this problem or know what it is????
Old 02-09-2005, 05:10 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Re: Re: acceleration problem
yeah i gotta agree with you drumpet, sounds like the clutch lol, i dont think d-bo was being offensive or anything, just a suggestion.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
