| Off-Topic Talk about anything other than cars. |
95 Talon Staring Problems
First off I'm new here so let me say hello to everyone.....hello. So here's my problem, I went to start my 95 Talon this morning and got nothing. The only noise the car is making is one click which sounds like the starter and a loud buzzing noise under the passenger side of the car. And the light in the car also come on, if thats any help. Has anyone encountered a problem like this before with the car not starting a just making a buzzing sound. Also do you think there might be somthing fried under the dash and thats what's making that buzzing noise? Thanks for any help anyone can give me, also I'm looking forward to this being my new home for car help.
Re: 95 Talon Staring Problems
It could be a couple of things. What you are hearing is the starter (the click and buzz). There are 2 reasons this will happen.
1. You don't have enough juice (battery power) to turn everything over. And don't think that because all of the lights come on that you have enough power. Grab another car and jump start it (let it sit for a couple of minutes before you turn the key, so it has time to build up some cranking power) 2.) Your starter is shot. It might have a "flat spot" in it. This can sometimes be resolved by wacking it with a hammer while you turn over the key.....really, I'm being serious. In either case, I would try jumping it (because it is the easiest thing to do )Let us know what you find EDIT: You will also want to check the battery terminal connections for corrosion (clean them if needed). A can of pepsi is the best for the cleaning.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Thanks, thats what I'm thinking too, only bad thing is can't make sure until tonight because I can't get a jump from anyone right now but by tonight i should be able to. Thanks for the info and I'll let you know what happens.
I had this problem before and it ended up being the starter selenoid.. Also does your car have keyless entry or a security system. Sometimes if my alarm is turned on and i dont notice I go to turn on the key and only get a buzzing sound, then if i deacticate it it starts. Something else you might want to try is turn your key to the on position then hot jump your car from under the hood using a wire ( do this by bridging a wire between the 2 bars sticking out of your starter selenoid ) If you're not sure what this is u can see a pic of one here.
http://www.saturnsurplus.com/genset/startsel.jpg You could also have a low charge in your batter, you could either try jumping it or do it the safe way and put a battery charger on it and see how many volts its getting.
1995 EAGLE TALON ESI Eclipse Conversion Kit/Bomex Side Skirts/BMX Rear/Blitz Front 17" Rims/Yokohama Tires Pearl White Paint CF Hood/CF Tail Lights/Headlights Aftermarket Spoiler Cat Back Exhaust 50 hp Shot Nitrous/Side purge system Aftermarket 12psi Stage 3 Turbo Cold Air Intake/Greddy Intercooler S3 Racing Chip Front/Rear Strut Bars Short Shifter/Racing Clutch APC Racing Seats Navy Blue Carpet Dual Guages/Custom Paint Alpine/C7 Sound System 3 12" subs in custom trunk box |
I just thought it was funny the subject says staring problem
also put your car in your signature
Year, Make and Model, Transmission also any mods you have. |
I've seen a low battery or bad terminal connections cause this. The click is the solenoid actuating, there is not enough power to turn the start motor, and the voltage drop causes a relay under the dash to flip out. My 95 GSX does ths all the time when I kill the battery running both radiator fans in the staging lanes...
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Thanks for all the help everyone, I put a jumper on it and it's fine now. I'm gonna have the battery replaced asap. Also where is good place to get body kits for my car.
Good to hear it is working...
As for body kits check out the VFAQ sticky at the top of the Eclipse/Talon/Laser forum.
"You can have everything in life you want if you will just help enough other people get what they want."
