Old 02-07-2005, 07:39 AM
cj_baller13's Avatar
cj_baller13 cj_baller13 is offline
Send a message via AIM to cj_baller13 Send a message via Yahoo to cj_baller13
out door pics of beetle
bear in mind that this is my first time working with milliput and first real attempt at airbrushing lol so be gentle:
tell me what you guys think?
Christmas Project- Beetle Cabriolet Diorama
"seven straight summers, critics might not admit it, noboddy in rap did it, quite like i did it. if u did it i dont it before you, if got it i had it got mad at it and not want it no more..." Jay-Z the gift and the curse
Old 02-07-2005, 09:08 AM
Re: out door pics of beetle
c'mon guys be ruthless i dont mind critacism (spelling lol)
Old 02-07-2005, 11:27 AM
NOSFERATTU's Avatar
NOSFERATTU NOSFERATTU is offline
Send a message via ICQ to NOSFERATTU Send a message via MSN to NOSFERATTU Send a message via Yahoo to NOSFERATTU
Very sweety.
Old 02-07-2005, 01:43 PM
blubaja's Avatar
blubaja blubaja is offline
Hey,
THe side view looks like the subaru 360. This the revell kit? Keep up the good work.
Frank X.
Old 02-07-2005, 02:27 PM
its the tamiya kit no. 24136 1880*, cheers for the comments
Old 02-07-2005, 02:28 PM
racer917's Avatar
racer917 racer917 is offline
oh no, no, no.
that's just plain ugly and bad
Old 02-07-2005, 02:36 PM
errrm lol constructive critacism prefered lol
Old 02-07-2005, 02:39 PM
sportracer02's Avatar
Hi,
the top line of the widening along the middle of the door and the fenders isnīt straight, you added is too much miliput.
Everything should look acurate before you airbrush.
I agree with racer917.
Micha
Old 02-07-2005, 02:41 PM
kicth's Avatar
kicth kicth is offline
Did you airbrush it or just regular brush?
The paint job doesnt seem smooth though.
Old 02-07-2005, 02:53 PM
Magliano's Avatar
Magliano Magliano is offline
Hey Cj_Baller13.
Well, your car is creative. But has a lot to improve.
Try to sand a bit more the wide body ou created.
The paint could improve too, but the sanding part would already give you a better result.
Ok!? Hope you finish this model.
keep us update ok?!
Bye
Magliano
Old 02-07-2005, 03:22 PM
008's Avatar
008 008 is offline
Too much putty work. That area between the front and rear fenders could've been done with sheet plastic so that it would look flat, then fix the problem areas with putty. All you used is Milliput?
Sheet styrene is not very expensive, and you can even use "For Sale" signs. Styrene is also MUCH easier to work with than putty, believe it or not. Cut to shape with scissors and needle files, and test fit until you get the pieces to match up. When you've got one side done the way you want it, you can easily copy the styrene sheet for the other side. Use super glue (CA glue) with an accelerator. If you can't find accelerator use baking soda sprinkled on the glue joint. Liquid glue makes a mess and won't dry strong enough for this type of work.
Good idea on the styling, just keep practicing on your fabrication.
-Ron
Old 02-07-2005, 03:44 PM
Wheelin75r's Avatar
Wheelin75r Wheelin75r is offline
yep, some more sanding will bring justice to the idea you have in your head of this beetle. Color is nice.
Old 02-07-2005, 05:07 PM
cheers guys i will keep all this in mind, i think i might sand it all down and start fresh, or just buy a new one lol thanks again
