Old 02-06-2005, 10:57 PM
Killa's Avatar
Killa Killa is offline
left signal blink problem ?
why my left signal blink faster then my right signal ?
Old 02-06-2005, 11:55 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: left signal blink problem ?
one of your left side blinker bulbs is out.
95 Talon TSI AWD
97 Eclipse GST
Old 02-07-2005, 07:59 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You probably need some of this
http://www.kalecoauto.com/fluids.htm
The one at the top.
I'm sorry.....I'm just screwing around
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-07-2005, 08:47 AM
Killa's Avatar
Blinker Fluid ? I never heard of that , BTW where is the left blinker bulbs located ? .
Old 02-07-2005, 02:35 PM
blue94eagletalon blue94eagletalon is offline
try moving the connection at you front turn signal around. if its blinking fast i promise that is what it is. i also bet that your front turn signal dosent work when its doing that even though your back one works. you just have to move the front bulb until it works. try it with your signal on.
Old 02-07-2005, 10:26 PM
Killa's Avatar
Today I just turn on the car , and flick on the left signal , then I went front of the car and check if the light is working , it blink , I went to the back of the car , and find out that my far left signal is not work , so I guess I had to buy a new bulb, ( where can I buy a good bulb ? , thanks.
Old 02-07-2005, 10:48 PM
just any regular bulb from an auto parts store will work
95 Talon TSI AWD
97 Eclipse GST
Old 02-07-2005, 11:06 PM
Killa's Avatar
thanks
Old 02-08-2005, 12:16 AM
make sure you get the right bulb though. get the same one that you are replacing. there are a bunch that look the same, but they're all different so make sure you get the right one. i believe it's an 1157 or an 1156, but check just to be 100% sure.
95 Talon TSI AWD
97 Eclipse GST
