b16 vs b18
hey guys i was thinking bout how much a tranny makes a difference in a car. i was wondering if anyone had lets has a b18 with the ls tranny and swapped a sir tranny without any other mods. to see what difference just the tranny would do. i guess the reason why the sir is faster than the b18, would be cause of the tranny, right. if a b18 had the same tranny as a b16 would they be equaly fast. just something that made me think a bit..
stock b18a1 14.97 @ 92 mph |
Re: b16 vs b18
Yes the tranny would make a difference but the siR has 160HP and 111TQ compared to 130Hp And 121TQ. I've beaten a CRX with B18A and a siR Tranny, I mean he took me off the line but I caught up and passed him by like 1 1/2 cars. And I have a JDM B16A1 in a 91' CRX
Re: b16 vs b18
yes a b16 trans will make yoru b18a faster but your not going to beat a b16 just because of a tranny change. and with the shorter gearing and the early redline of the ls, your going to top out that tranny earlier. the b16 tranny is meant for high revving motors
Re: Re: b16 vs b18
Re: b16 vs b18
No, you're better off to go with the SiR tranny.. Even with a turbo.
Shorter gears = faster B18s with an SiR tranny are quick, with an LS tranny they aren't that spectacular. |
its better to get a gsr or type r tranny than a b16. the b16 tranny isnt built as strong as the ls gsr or type r trannys. it may have short gears but it cant handle power as much as the b18 trannys. I would get a type r tranny if you can.
1991 Honda Civic DX Sedan |
Re: b16 vs b18
if you are going like 300whp or less with an ls. the b16 tranny will do fine. just dont try and use it to run 10s with an ls motor. |
Re: b16 vs b18
Is the SiR tranny made out of a different metal than the B18 trannys or something?! Sometimes I wonder about you...... |
Re: Re: b16 vs b18
ya i really like the ls tranny for the street and highway, so i am not sure what to do. casue i drive alot with my car.and the ls tranny is easy to come accross. i guess the best way is to acctually try one out.i figured to get the best of both worlds would be to build the engine more and to stick with the ls tranny for drivability.
Re: b16 vs b18
the only trans that is stronger is the type r because of hte lsd. hondas are known to break stock diffs, but an lsd makes it good
Re: b16 vs b18
No doubt. Other than the gearing ratios and the FD, I'm sure there's no REAL difference between a B18 and B16 tranny, other than a couple of them comming with LSD as mentioned. Some B16 trannys were also available with the LSD.
Re: b16 vs b18
just go lsd its the best i got jdm b16a with lsd and it rocks..
Re: b16 vs b18
2 crxs
Both are the same year and have the same mods. Both driver's have the same driving abilities. In Fact they are the exact same car. One has a B16a The other has a B18b (not a B18a) They are both running the Y1 B16 tranny. The vehicle with the B18b takes off the line and jumps out by 1.5 cars with the 18 extra ft/lbs of torque. The B16a falls behind and is unable to catch up. Why? Because the B18b is running the B16 tranny which is the only advantage the B16 has over the B18b. People will say that "yah but the b16 has vtec yo". The b16 seems much faster than the b18b because the b16 gearing compliments the vtec. Same would be true as a b16a with an LS tranny? Anyone every see this combo? It's super-slow.... The b18b equipped crx with the ls tranny would beat it in this case as well.
Re: b16 vs b18
The only reason that any 92+ bseries tranny is "better" is because it has a slightly larger input shaft and can handle slightly more power...nothing to brag about. So yes, in that sense, it is a little stronger than the 89-91 b16 trannies from japland.
Re: Re: b16 vs b18
