Old 02-06-2005, 07:46 PM
jmroth jmroth is offline
fog lights add on 94 astro
where on the fuse box should i hook up fog lights on 94 astro
Old 02-07-2005, 09:53 PM
Kings-x59 Kings-x59 is offline
Re: fog lights add on 94 astro
Look for an empty "accessory" fuse slot in the fuse block. If you can find one, this is the one to use.
make sure the fuse slot amperage matches the fog lamp amperage. The upside to this is that when you turn the key off, the fog lamps shut down. You won't drain the battery by accident. Otherwise, any empty fuse slot with a matching amperage will work. * Keep the in-line fuse in the fog lamp wiring*
Old 02-08-2005, 12:53 AM
hi kings-x59 thanks for the hot tip i had a double y plug for my fog lights and cb radio to cigarette plug consequently heating up plastic hole in console to lava like temperature, so all those extra hot leads above stock fuse holders infuse block arepotential exsessorie outlets,yes??
Old 02-08-2005, 10:35 PM
Any empty fuse slot will do the trick. Make sure the amperage matches your fog lamp amperage. Don't go plugging 15 amp fog lamps into a 30 amp fuse slot.
