Old 02-06-2005, 07:36 PM
2000astrovan 2000astrovan is offline
Dome lights when door opens
2000 Astro LS
When I open the doors the inside lights will not come on.
It doesn't matter which door, none will work. If I roll the dial
next to headlight switch they will work, just not when you open
the doors. Any ideas.
Thanks
Old 02-07-2005, 10:02 PM
Kings-x59 Kings-x59 is offline
Re: Dome lights when door opens
Does the 2000 have an interior light switch? ( other than the dial?)
Old 02-08-2005, 09:16 PM
No I Don't think so. If it does i can't find it.
Any ideas? Thanks
Old 02-08-2005, 10:30 PM
OK, if there is no interior light switch, check your fuses.
Check the bulbs. It'd be unlikely that they'd both burn out at the same time, however I can't say I know how they are wired. If they are wired in series like cheap christmas tree lights, one burnt out bulb kills the circuit.
If opening any door doesn't kick the lights on, most likely it's a fuse. If it turns out the fuse is blown, and a newly installed fuse blows as well, there's a short in the circuit. Most likely culprit is worn insulation abraded on metal somewhere that is grounding out.
Old 02-13-2005, 01:34 PM
chopchop chopchop is offline
Originally Posted by 2000astrovan
2000 Astro LS
Thanks
My 1995 GMC Safari has a slide bar on the dash, Interior Lights = Off or Door. When "Off" the only way to turn on interior lights is like you said with the contrast wheel.
Old 02-15-2005, 09:05 PM
My '89 does too. Right next to the rear a/c switch. When it's in the off position, the dome light only comes on with the contrast wheel.
Unfortunate if GM dropped this switch from the dash. Mine keeps my kids from running down the battery by leaving a door ajar.
Old 03-30-2005, 12:56 AM
demotim00 demotim00 is offline
There should be a push button on the driver side of the dash, right underneath the headlight switch and interior light rocker. It is the dome light override button. If it is pushed in, your lights will do the same as you describe. If you depush it, than it should work normal.
