Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-06-2005, 06:19 PM
cathyinmo cathyinmo is offline
1988 lude..ignition module?????
Hi..my car just started this...driving then car cuts out and dies, I pull over and wait about 5 min, car fires right up and I can go about a mile, then same thing. I cleaned the injectors, the car actually came up a steep hill! BUT a few min later..same thing. Whatever the problem is, it seems to only do it after the car gets warmed up. Someone told me it could be the ignition module, but when I looked in a manual, there was nothing about one. Ideas?????
Old 02-06-2005, 07:51 PM
hontoy's Avatar
hontoy hontoy is offline
Banned
Re: 1988 lude..ignition module?????
not enough info to diagnose your problem. you need to tell us more. could be just some out of range signals from bad sensors. the bad signal causes the ecu to shut down your injectors. is your car obd2? if so, plug in some obd2 scanner and tell us all the numbers from your freeze frame data. then we can diagnose your problem.
Old 02-07-2005, 03:37 AM
Re: Re: 1988 lude..ignition module?????
OBD2??? Whew lol lost me! Is there anything else that could help?
Old 02-07-2005, 07:55 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
Does all of the electrical die when the motor dies?
Old 02-07-2005, 03:53 PM
yes I believe so
Old 02-10-2005, 01:48 PM
ProjectPhantom's Avatar
ProjectPhantom ProjectPhantom is offline
i dont think the car can even start up if the ignition module is out... can it? and thise 88's were obd1
Old 02-10-2005, 02:21 PM
OH GREAT! lol, any other ideas then?? and what is
obd1???
Old 02-11-2005, 11:14 AM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
obd1???
My car did the same thing, I wish i could remember what the problem was though? jeeze, its a recall part I know that, I'd check with honda, they should swap in the part for free.
On mine it could die anywhere in the middle of the intersection, it didn't matter, but I do believe its a recall.
Old 02-11-2005, 11:41 AM
A recall for an 88? So far it's down to ignition module, distributer or maybe a c? sensor
Old 02-12-2005, 05:23 PM
jdrumstik's Avatar
if I remember right it was the distributor.
Old 02-26-2005, 02:46 PM
hossin hossin is offline
It is the relay that is located under the dash on the driver side of the vehicle. Take out the fuse box tray and it is on the left side of the fuse box. Matsuba relay ass'y, main RZ-0045 12V You need to pull it out, if it smells like really badly burnt rubber, then it needs to be replaced. This is common on all 88-89 ludes.
Rob
Old 02-26-2005, 08:06 PM
Thanx every1 got it fixed...the fuel pump
