Old 02-06-2005, 05:05 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Transmission Swap
Could I put a 92 or 94 Mitubishi Mirage transmission in my 91 Mitsubishi Eclipse???
Old 02-06-2005, 06:26 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Transmission Swap
what's wrong with the eclipse transmission? if it's bad, replace it with the same one, that way you don't have to fuck with the sensors being different and all that bullshit.
95 Talon TSI AWD
97 Eclipse GST
Old 02-06-2005, 06:42 PM
Re: Re: Transmission Swap
My transmission has 208,000 miles on it and i can get a free tranny out of a 92 or 94 mirage.
Old 02-06-2005, 06:45 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
wait till the old one breaks. unless you've had the car since new it might have a rebuildt/new trans in it already
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-06-2005, 07:56 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
you might be lucky enough to swap some of the inturnals out of the mirage trans and get them into your eclipse trans....but im pretty sure its not a direct bolt on or if it will even work at all....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
