Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-06-2005, 03:33 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
hot rod blower
I have this magazine saying that the classic hot rod blower is an exhaust scavenging pump from a 4-71 or 6-71 gmc diesel.\
1) what is an exhaust scavengin pump?
2) how expensive is it to buy one?
3) how difficult is it to install as a blower?
4) where can i find one?
5) what is a 4-71 or 6-71 diesel (what do the numbers meen)?
any help would be greatly appreciated.
Old 02-06-2005, 11:22 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: hot rod blower
an exhaust scavenging pump was an air pump they used on old diesels to suck the air out of the combustion chambers after igntion to let the new air in without forcing it in. With the new giant turbo diesels this isn't an issue.
you can buy them here: http://store.summitracing.com/defaul...5239&x=17&y=12
They are bolt on kits for ford and chevy small and big blocks. If you don't have one of those engines you need to either find an intake manifold made for a weiland blower or make one yourself.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-10-2005, 04:41 PM
SaabJohan SaabJohan is offline
Re: hot rod blower
The numbers 4-71 and 6-71 means 4/6 cylinders, each of 71ci. This is how the two stroke diesel engines was designated.
As you might know a two stroke engine can't breathe by itself. If you take a look on a small two stroke engine you will find that it uses crankcase compression to feed the air to the cylinder. This isn't used with larger two strokes, instead they have a separate airpump to feed the cylinders with air. On the diesels 4-71 and 6-71 the compressors was used for exactly that. See picture below.
Old 02-28-2005, 08:23 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
Re: hot rod blower
Impressive!
<elmer fudd>
Be vewwy vewwy quiet, I'm hunting Morons. Heh heh heh heh.
</elmer fudd>
