Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-06-2005, 03:27 PM
SLoe's Avatar
SLoe SLoe is offline
fuel cut @ 13psi?
I hooked up my MBC,and boost gauge, and even with the knob all the way in I can't get over 13psi. I have hooked it up two different ways, input from the turbo nipple, and from the BOV. I am also getting fuel cut, and a CEL. I have found no boost or vacuum leaks.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-07-2005, 11:04 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: fuel cut @ 13psi?
What is the CEL......Did you have it scanned? I don't see how you are getting fuel cut with the T-25. See what the CEL is and let us know.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-07-2005, 12:46 PM
SLoe's Avatar
I don't have a scanner, It will be a few days before I can get to the shop. I will let you know then.
Old 02-07-2005, 06:30 PM
SLoe's Avatar
I was looking for vacuum leaks, and noticed that my EGR solinoid is busted. Do you think this could be part of the problem? It has some nasty backfires.
Old 02-09-2005, 05:38 PM
SLoe's Avatar
Good news for me, it was not fuel cut. I found the egr solenoid to be busted where the vacuum line attaches, so instead of buying a new one I just made a block off plate. Problem fixed no more backfire or bucking. I didn't even get a CEL, though I thought I should have.
Old 02-09-2005, 06:18 PM
SLoe's Avatar
Stupid me, I crossed the vacuum lines to the mbc. I had the input on the output and the output on the input. I just made a couple of runs, and got the boost up to 16psi, with only 1 or 2psi spike.
Old 02-10-2005, 07:55 AM
Wooops!
Well, they say you don't learn anything without making mistakes. Glad to hear you are up and running!
1997 Spyder GS-T
5-Speed
