Old 02-06-2005, 04:01 PM
97_pontiac_gtp 97_pontiac_gtp is offline
Unhappy fuel pressure drops from 48 to 0 but starts up then shuts off in few seconds
1997 pontiac gtp i hooked the fuel pressure tester up turned the key on the fuel pump kicked on then stoped like it was pressureized then started the car the pressure when to 48 to 0 in like 2 seconds what do you think it is regulator? or pump? the car was low on fuel and the warning light was on i ran it for a while then the next time i tryed to run it it was staling out so i put gass in it and it still continues to stall.
where is the regulator on this car? do you have to drop the tank to get the pump out or can you take it out threw the trunk? what do you thinks wrong?
Old 02-06-2005, 04:08 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Sounds as if you may be having a problem the the fuel pump resistor.Try doing this at the under hood fuse box and see if it run's.
~Larry~
ClubGP Member 6530
Since 2001
Old 02-06-2005, 05:16 PM
Re: fuel pressure drops from 48 to 0 but starts up then shuts off in few seconds
~Larry~
so you pull that fuse thing out and bend one of the tabs side ways? what does it mean now if the car runs or doesnet? what do you fix? whats that thing called
Old 02-06-2005, 05:41 PM
BIG-L's Avatar
Pull out relay 15 and bend tab 85.If the car start's and run's ,your fuel pump resistor has gone bad.
ClubGP Member 6530
Since 2001
Old 02-06-2005, 06:16 PM
Re: Re: fuel pressure drops from 48 to 0 but starts up then shuts off in few seconds
i was checkin it out but it got dark ill have to do it tomarrow number 15 is f/pmp speed cont number 14 is fuel pump on my diagram there was no number 85 on the relay anywhere but if its just that 1 tab in the corner like your picture ill do that tomarrow and see thanks for the help
Old 02-07-2005, 05:37 PM
whats that #85 i didnt see no 85 on the relay
