Old 02-06-2005, 02:57 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
V8 3000gt/stealth's?
Do you guys know of any V8 converted 3000gt/stealths? i just saw this V8 converted starquest and started wondering if it was doable on a 3000gt/stealth becouse i think these cars wuld make a cool RWD car
http://www.mmatkosky.homestead.com/
Old 02-06-2005, 03:29 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: V8 3000gt/stealth's?
I've seen a V8 drag car for sale on ebay, I The only thing that made it a stealth was the body lol.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-06-2005, 07:58 PM
StealthModifier StealthModifier is offline
yea, ive seen a funny car as a stealth at the track a few years ago
Old 02-06-2005, 08:09 PM
s
ohh man. tease car's wuld be awsome with a V8 still baybe it's no simple task to fit a v8 in the hood its so low that the big 8cylender beast may not fit to good in there
Old 02-06-2005, 08:12 PM
the V6 barely fits in there, no way a V8 will
Old 02-06-2005, 08:59 PM
Hotshot8792 Hotshot8792 is offline
Re: Re: V8 3000gt/stealth's?
you'd be surprised what money and fabrication can do. Yes, i know of one person with a v8 in his car, he calls it a vr440, cause its got a 440 in it i believe. If you search it on 3si, you'll find out more about it
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 02-06-2005, 09:04 PM
well as you can see this guy did fit a 5L v8 in his conquest wich were only 2.6L so i think its possible.... the main thing that i think prevents it being easy on the stealths is the transmission there is realy no good place for it!
Just the other day i saw a bore stroke kit for the 6g72 block. to make it a 3.2 or a 3.3L has anyone done this to their car here?
Old 02-06-2005, 10:41 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
where did you see/find this bore and stroke kit? i'm curious. i've never seen one, but that could really help us make some more power, torque especially for the NA guys.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-06-2005, 11:35 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
The stroker kits are known to be bad news for these cars. As far as V8's there are a few V8 converted 3s's. As was mentioned VR440 is one and there are a few others.
Old 02-07-2005, 06:14 AM
do you guys know of any pics of thease cars?
http://www.importperformanceparts.ne...its_mitsu.html here is the stroker kit
and here are better pistons used by the "stealth316" guy.... this shuld make more displacement as well http://www.stealth316.com/2-venolia.htm
Old 02-07-2005, 05:44 PM
right, but with vr440, he mounted his engine for rwd, and and doesnt have a 3/S tranny in it either, but i'm not sure the full set up on it. I just know that the engine and tranny are mounted orthogonal to a stock 3/S.
Old 02-07-2005, 08:47 PM
Linebckr49's Avatar
Re: Re: Re: V8 3000gt/stealth's?
Originally Posted by Hotshot8792
engine and tranny are mounted ORTHOGONAL to a stock 3/S.
orthogonal...haha, good word Hotshot. i like to see and hear a little engineering jargon every once in a while.
ya, so its orthogonal mounting position is almost requisite for RWD applications as the transmission interface is much simpler and readily available. I've spoken with some auto technicians, and have found out that the transversely mounted engine in our cars is ideal for introducing the same engine upon different chassis. but transversely mounted engines don't make the RWD interface easy. if you look at the 300ZX and the Supra, their engines are both longitudinal. the former being a "V" configuration while the latter is an inline. However, i'll give it up to the mitsu engineers for throwing in the AWD package on the VR4. good choice!
93 3000GT base
Old 02-07-2005, 11:22 PM
Stealthee's Avatar
Re: Re: Re: Re: V8 3000gt/stealth's?
As stated go to 3si and search for stroker. You will see reviews on the kit. The way it is done it is bound to break quickly. You are better off just going with a slight overbore for more displacement.
Old 02-08-2005, 08:37 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
well mabey you could look in to a cadillac V8 or a Arura... they have side ways v8s lol mabey someone can take a V8 out of one of them mabey even find a all wheel drive tranny for one. Yes the engine mounts will be different but its better then refabricateing the car... though you might need to do a little but not as much as a rearwheel drive tranny...
Upgrades... To many to list...
Old 02-08-2005, 01:33 PM
Ohh man thease cars wuld have made such a nice ride instead of the FF but i wuld still like the 4wd on the turbo ones. such a shame that they did not make them rwd actualy i not to shure that MMC made a car after the MMC Starion that had a rear wheel drive or is there?
