Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-06-2005, 01:59 PM
oxygen800r's Avatar
oxygen800r oxygen800r is offline
Question weird rubbing sound?!?!??!?
first off:
1998 eclipse gst
now then, when i turn in either direction, i'm starting to hear a strange rubbing sound that seems to be coming from my passenger front wheel area. it's not a grinding type of sound that you would hear with a busted cv. it's more of a flat tire rubbing across a gravel surface type sound that doesn't occur every time i turn, but maybe 1 out 3 times i turn.
i checked the cv boot for any tears where grease could escape but there's nothing. no grease anywhere in the area or on my wheel. i ruled out the cv/axle problem.
after that, i checked ps fluid and it was fine so no leaks there.
i have no idea where to go from here.
would a busted shock make a sound like that? how do i tell that it's tossed, if it is in fact my shock? and again, if it is my shock, where can i find a place to rebuild it? i run koni yellows.
HELP!!
Old 02-06-2005, 06:16 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: weird rubbing sound?!?!??!?
is your car lowered? check for weird wear on your tire from it dragging on something.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-07-2005, 09:55 AM
oxygen800r's Avatar
the car is lowered. no uneven wear on my tires.
it's driving me nuts!
