Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-06-2005, 01:51 PM
jeepdud jeepdud is offline
94 grand cherokee tranny problem
I have 94 grand cherokee with 42re tranny ,problem is i go to take off and the engine reves high but the jeep just creeps forword and if i slap it in first gear it takes off ok , if I'm at a stop it jurks them stop just like its coming in and out of gear. i also notice that it seems to be shifting to fast,like it comes out of first gear 20kmp. the rest of the gears are ok.Now i tried a new valve body and it did the same,i rebuilt the tranny and it still doing the same thing ,i also replaced the torque converter and it still doing the same thing.I scanned the tcm and didn't find no codes,but i went for a ride with the scanner and it felt like the trans was shifting (to fast)but the scanner wouldn't pick it up.If anyone could help me cause i'm stumed.
Old 02-06-2005, 10:30 PM
JDPascal JDPascal is offline
Re: 94 grand cherokee tranny problem
When you rebuilt the tranny, did you replace the oneway clutch on the low/reverse drum??
If I remember my automatic operation right, that one way clutch holds the drum during normal automatic operation ( starting of with the shifter in drive) for low gear. Using manual low engages the low reverse band to create the gear.
JD
Old 02-07-2005, 09:10 AM
NO but it didn t look damaged.
Old 02-07-2005, 09:57 AM
Ironic Ironic is offline
Not sure about the 94 year, but I had a shifting problem simular to yours (89) and found out the tps was bad.
Old 02-07-2005, 12:20 PM
Also check the adjustment of the kick down cable that attaches from the throttle to the transmission.
JD
Old 02-11-2005, 05:35 PM
sandgrand94 sandgrand94 is offline
I also have a 94 that does the exact same thing did you find the problem?
Old 02-15-2005, 03:08 PM
lloydjv lloydjv is offline
Sounds like your throttle valve cable needs to be adjusted.
Old 04-19-2005, 07:23 AM
fusion27 fusion27 is offline
JD
Hi JD, i got the same problem with my 94 grand cherokee, am about to change the tranny, a freind of mine got a 94 cherokee sport, will his tranny fits onto mine? the plate with the s/n is missing so i can't tell what kind, but my freind got the same year, inline 6 with 4x4 like mines.
Thanks
DG
Old 04-20-2005, 10:22 AM
it would likely bolt up but you would have control problems with computer compatiblity. Better get a direct match and avoid all that hastle.
JD
