Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-06-2005, 12:21 PM
70camaro 70camaro is offline
Question 4L60-E trans. problems???
I have read about some of these tranys failing, and how they start to shift hard before they go. Well, I had the hard shift phenominon afer long drives on hot days. I had the trans. flushed, and put val. max life in (about 100k). I haven't had a problem since. But my question is this: Is there a valve body responsible for the hard shifts, and eventual failure? And if so, is it something that can be fixed WITHOUT removing the trans from the truck? I am asking because even though mine has stopped shifting hard, I may want to get the valve replaced if it will save an entire reuild later.... (lazyness is it's own motivation!!)
Old 02-09-2005, 10:16 PM
flood zone flood zone is offline
Re: 4L60-E trans. problems???
hi, i was having the same trouble with my 99. tranny shop told me to upgrade the valve body for 450. i give him the go ahead and head called me back shortly and told me mine was in bad shape. he did a complete rebuild. that worked for about 4 weeks. it started shifting hard again today. go figure! i am taking it back to him tomorrow. cost $2000 so i would like it right. if you find out what could cause this to happen. please let me know. thanks
Old 02-19-2005, 01:57 AM
Akshay Akshay is offline
Valve bodies are inside of transmission. It gets stuck. Is only 1-2 shifts rough?
Owners usually get new transmission installed. It's a bit more expensive though.
Old 02-20-2005, 02:47 AM
2000CAYukon 2000CAYukon is offline
Re: Re: 4L60-E trans. problems???
True the valve body is inside the transmission; however, it can be removed without removing the transmission from the vehicle.
The pan and filter need to be removed to get access to the valve body.
70camaro, you should look at a having a transgo reprogramming kit installed. It fixes a lot of issues with the 4l60e and improves shifting and 3/4 clutch life.
When they have the valve body out, any valves that are not replaced with the transgo kit can be repaired/replaced if worn.
The kit I am refering to is the transgo 4L60E-HD2 reprogramming kit.
//2000CAYukon
Old 02-21-2005, 08:34 PM
Yukon, is the Transgo kit a parts install, or a reprogram for the computer, or both? I might just do it if I'm going to be in there anyway...
Old 02-22-2005, 01:29 AM
The kit is a parts install. No computer mods required. I guess it is called a reprogramming kit because it increases line pressure (like a computer reprogram). It also replaces certain springs, the 1-2 shift valve and other parts.
The installer will ask you how you want the shifts (firm, mild, race). I bought the kit for my 96 Impala SS with 65K miles on it. I am not going for extra firm shifts. My purpose is transmission life and some performance. I am just waiting for a dry weekend to install it. Hopefully, next weekend.
A lot of the tranny rebuilders install this kit as part of a rebuild.
//2000CAYukon
