Old 02-06-2005, 11:07 AM
gijim19 gijim19 is offline
Question oil pressure sending unit
OK. I bought an oil pressure sensor from NAPA when my oil pressure went sky high and stayed there. I wasn't worried until I changed my oil. I drained a quart....maybe. OK panic time here. I get the unit and now I can't find where the darned thing screws in. And it's not covered in the Haynes manual. This sucks, big time. Any help would be appreciated.
Old 02-06-2005, 11:31 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: oil pressure sending unit
year? engine?
Old 02-06-2005, 02:19 PM
oops. I forgot to include some info. It's a 1993 4.3L V-6 (non-Vortec)
Old 02-06-2005, 05:41 PM
blazee's Avatar
Problem?
Should be towards the front on the drivers side, below the exhaust manifold.
Old 02-06-2005, 08:08 PM
BlazinUP BlazinUP is offline
anyone know where it is on a 93 vortec?
Old 02-06-2005, 08:30 PM
blazee's Avatar
Problem?
Re: Re: oil pressure sending unit
Check the passenger side just above the oil pan.
Old 02-07-2005, 08:24 AM
smokey041369 smokey041369 is offline
oil pressure switches
4.3 : top,rear of engine,driverside of distribitor
96-4.3 vortec: driverside head between cylinders 3 & 5
96-2.2 :front of engine under thermostat housing
2.2 : looking at passengerside of motor top right of coil pack
2.5: under lifter plate between cylinders 2 & 3
2.8: rear side of oil filter driverside of engine
hope this solves the oil pressure switch questions
Old 02-07-2005, 09:45 AM
blazee's Avatar
Problem?
Re: oil pressure switches
We're talking about oil pressure sending units, not the coolant temperature sending units that you listed.
Old 02-07-2005, 12:46 PM
Mango™'s Avatar
Mango™ Mango™ is offline
If we figure out where it is, my pressure stays high for years now, I need to replace mine too, does anyone have an picture of it, thanks
Old 02-07-2005, 12:52 PM
blazee's Avatar
Problem?
year? engine?
Old 02-07-2005, 01:58 PM
blazee before you try to say i'm wrong check this out for yourself
hayes chevy, gmc s-10& s-15 82 - 93 page2a-2 fig 3.5 page 2c-7 fig7.7b page 2d-2 fig 1.1b
chilton gm s-series p/u & suv page 2-14 fig 41-96 2.2, fig 42-96 4.3. fig 43-4.3, fig 44-2.2
the only change on the 4.3 was in 96
Old 02-07-2005, 02:27 PM
blazee's Avatar
Problem?
I don't have those books, I have the Haynes manual for 94-01. The ones you list for the 96 year models are shown as coolant temperature sending units in this book.
Old 02-07-2005, 04:04 PM
Mango™'s Avatar
ooops, If we figure out where it is, my pressure stays high for years now, I need to replace mine too, does anyone have an picture of it, thanks
1991 s-10 4.3l v6
Old 02-07-2005, 05:28 PM
Oil Pressure sensor: round 2
Thanks for the help. I found the unit right away. Now comes the challenge, taking it off. Get this, the new sending unit fits the sending unit socket but the old one doesn't. I hate technology. I geuss it's a good thing I have to pull the distributor anyway, otherwise I'm never going to be able to fit the 1-1/16 wrench I've got to use. Thanks again. The info was great and the rest is on me.
Old 02-07-2005, 07:22 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
For the record, on all 4.3's it's in back of the motor next to the distributor..Simply use an oil sender unit socket to remove. You will typically need two if it's your first time. The larger one for the stock, the smaller one for the aftermarket unit...
