Old 02-06-2005, 10:39 AM
slreno1217 slreno1217 is offline
adjusting doors an a 89 chevy 2500 scottsdale.
the doors on my 89 are sagging a bit. is it feasable to remove the door and bend the hinges up about a 1/8 to a 1/4 inch with a pipe wrench to fix this problem?
Old 02-06-2005, 12:06 PM
cordovaass's Avatar
cordovaass cordovaass is offline
Send a message via AIM to cordovaass
what you need to do is get a new set of hinge pins. www.ckresto.com they are $19.95
Old 02-06-2005, 01:54 PM
Re: adjusting doors an a 89 chevy 2500 scottsdale.
i have read horror stories about getting the old sleeves out.. ya know the metal busshing.
are they as hard as i have read?
Old 02-06-2005, 03:14 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Just put a floor jack under the doors and jack it up.
Old 02-06-2005, 05:27 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Holy shit some people have some crazy ideas on how to make adjustements to vehicles. If your doors are sagging the hinge pins are worn out and need to be replaced plain and simple. Why try bending the hinges or jacking the door up to make it close better, all that is going to do it wreck it. The hinge pins and bushings are EASY to replace , i have done it a few times in the past and i say the easiest way is to do one pin and bushing at a time starting with the top one just get someone to support the door while you tap out the old pin and bushing with a hammer and punch.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 02-09-2005, 06:56 AM
well replaced the pins and bushings. and never fixed it. looks like the holes in the hinge on the door are rounded out a bit. again back to the original question! slightly bending the hinges . is it feasable or will they just bend rite back after the door is back on?
Old 02-09-2005, 12:32 PM
broughy84's Avatar
broughy84 broughy84 is offline
Put a floor jack under the door and a 2x4 between the two. SLOWLY jack the door up. SLOWLY! Becareful. Go a little bit at a time. My door sagged about 1 inch, and I slowly raised it. It took me about an hour or so. Jack it up a bit, hold it there for a few minutes or so, then let it down. Don't try to do it all at once though. You will tear something up.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 02-09-2005, 07:26 PM
kenny-1907's Avatar
There is actually a tool that is made to hook over the striker pin and then latch into the door so that it is almost closed (in the position where you can see all the body lines properly) and you use a crescent wrench on a hex nut welded to it for leverage. Most body shops should have one of these , maybe you could go and talk to someone at one and see if they will borrow it to you or even do it for you , it will only take like a minute. This method would be alot safer on the paint and sheet metal and this tool is actually made for adjusting doors in this way although in a jam the jack trick will work.
6" Pro Comp lift
K&N FIPK GENII
Old 02-09-2005, 07:30 PM
kenny-1907's Avatar
Here is a link to what the tool looks like
http://www.autotoolmart.com/cgi-bin/...16105303811.7e
6" Pro Comp lift
K&N FIPK GENII
Old 02-09-2005, 10:04 PM
cordovaass's Avatar
i'm telling you, if you care enough about your truck to do it right just get new hinge pins. im a bodyman and thats what i would do.
Old 02-10-2005, 11:19 AM
broughy84's Avatar
HE DID!
slreno1217 []
Status: offline
02-09-2005, 07:56 AM
(Post #6)
Matthew Brough
