Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-06-2005, 10:02 AM
137 137 is offline
when I use the breaks the oil light goes on.
I have an 86 bronco 2 and sometimes when I use the breaks, the oil light goes on. I have had the oil changed recently. Anybody know why it would do that?
Old 02-07-2005, 03:29 PM
Truck Truck is offline
You have a bad vacuum on the intake manifold? Reverse pressure?
http://www.hoppers.com.au/basics.htm
Maybe if your engine has 'blow-by' that the pressure could be blowing the oil backwards? (Maybe.)
Master Cylinders Make Pressure
To apply a hydraulic fluid pressure to the brake calipers, we use a master cylinder, in essence small pistons connected to your brake pedal which generates fluid “pressure” according to the force applied to it and the area of the piston by the formula.
