Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-06-2005, 09:54 AM
ndoerr ndoerr is offline
Angry yoda problems again
recently i just put a new alternator and a new voltage regulator in my 1980 Toyota pickup. for awhile everything went good, then the charge light came on, but when i put in my alternator i charged my battery fully, and the alternator should be charging the battery back up everytime i drive it, i have no idea what is wrong, i check for shorts in the wiring but couldn't find anything, so any help for what is wrong would be appreciated
Old 01-23-2008, 11:12 AM
swiftknight23 swiftknight23 is offline
Re: yoda problems again
well typically not charging indicates a bad alternator, id take it out and bring it to a automotive store so they can run a test on it, if by chance they sold you a defective alternator, it should be covered under warrenty. you might also want to make sure the wires coming from the alternator and not shorting out some where.
Hope this helps
Terrell
Old 01-25-2008, 11:31 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Rebuilt parts have a high failure rate. Take it back and have it checked.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
