Old 02-06-2005, 06:43 AM
chopperhopper chopperhopper is offline
cooling problems in my lumina
my lumina has a 3.1 and was overheating, while looking for the reason i found a coolent leak at intake gasket under themostat housing. so far this is just a minor problem,i replaced temp senser ,themostat,switched relays ,checked fuses.. i have 2 fans one that comes on according to coolent temps ( is working good now since changing temp senser) now my problem is... that the second fan that is suppossed to come on when ac clutch is engaged is not coming on at all, i pulled out the relay and jumped across relay terminals and got fan to work but when relay is installed ,nothing ! would this be a problem with ac compresser or a related switch?
Old 02-06-2005, 06:53 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: cooling problems in my lumina
Does the A/C compressor actually engage? If the compressor doesn't come on, the fan won't either.
The intake coolant leak is common on this motor. Watch your oil and coolant closely for signs of cross-contamination.
If the compressor is not engaging, you could try jumping the terminals of the low pressure switch with the A/C on, key on but not running, and the fan should start when the clutch locks in. If the compressor isn't engaging because of low charge, this will fool it into thinking it is full. But if the motor is running, the compressor might be damaged.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-06-2005, 08:20 AM
cadgear's Avatar
cadgear cadgear is offline
I noticed something quirky about my #2 fan.
When the AC is on, the fan is not..until the AC has been running approx 2 minutes. I assume this is the time it takes the condensor to start needing the extra airflow to cool the refrigerant. Of course, if the engine's been on a while, it warms the condensor anyhow, so when I click over to AC the fan jumps to life anyhow.
Just a thought?
Old 02-06-2005, 10:21 AM
Re: Re: cooling problems in my lumina
Just a thought?
You are probably right, there is probably a temp or pressure sensor that starts the fan now. I'm used to older systems. I'm gonna watch mine here in a bit and see if it's like that.
...empty gun rack.
Old 02-07-2005, 04:59 PM
You are right, my fan doesn't start with the compressor initially either.
...empty gun rack.
Old 02-07-2005, 05:35 PM
Unhappy Re: Re: cooling problems in my lumina
i was told my fan that is dedicated for ac is not working because outside temps are low and condenser wont build heat so there is no need for the fan to operate,,,,???????? i hope this is correct
Old 02-07-2005, 06:14 PM
Sounds right.
...empty gun rack.
Old 02-07-2005, 07:59 PM
cadgear's Avatar
Only time that second fan will kick on w/o AC intervention is if the car is in a dangerously hot condition.
Old 02-07-2005, 08:33 PM
thanks for the help
Old 02-10-2005, 05:14 PM
Dr Sparks's Avatar
Dr Sparks Dr Sparks is offline
Send a message via ICQ to Dr Sparks
Speaking of cooling, my 97 LX is starting to run hot. These things take a special coolant, do they not? Type?
Of course it wasn't doing this yesterday. IT WASN'T BROKEN YESTERDAY!!
Old 02-10-2005, 07:21 PM
cadgear's Avatar
Just Dex-Cool, if its 1996 or newer. Dex-Cool is orange, and "the green stuff" is..well, green. Check to see what color it is before adding.
Old 02-11-2005, 08:29 AM
Dr Sparks's Avatar
Thank you.
