Old 02-05-2005, 11:55 PM
Patryk10's Avatar
Patryk10 Patryk10 is offline
Sumthin's wrong
Sumthing's wrong with my Civic 92. I was peeling in first (high RPM) and then when i shifted to second, my exaust felt and sounded really different ...after when i stopped to check it out, it started to smell like sumthing was burning in my car. I dunno wats going on, this has never happened b4, surely i broke sumthing, but what?
Injector, piston, ...??? Anyone kno?
Old 02-06-2005, 11:48 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
What type of burning smell?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 02-06-2005, 03:51 PM
Patryk10's Avatar
smells like if sumthing was on fire, thats all i can say about the smell. i dont smell it outside tho, only in the car when i leave the car on (not moving)
Old 02-06-2005, 04:12 PM
CivRacer95's Avatar
CivRacer95 CivRacer95 is offline
srs biznis
Send a message via AIM to CivRacer95
Re: Sumthin's wrong
Chances are you blew a gasket in your Exhaust manifold. Take a small hose of some sort and turn the car on. Listen around to see if there is a leak in your pipe. Do the same underneath near your cat-convertor. Does it smell like gas when you accelerate?
Is there anything wrong when you shift the car too? Does it drive alright? Also, is there are a ticking noise that gets louder the more you push the gas pedal?
AF Guidelines. Read and play nicely :
Just Click Here!
Old 02-08-2005, 03:49 AM
Mingish's Avatar
Mingish Mingish is offline
Re: Sumthin's wrong
one time on the high way i went to pass a car..went down a gear and just gave it..something went..car felt really funny..then i started to smell something burn..had a high flow cat and i blew the filter inside..it took afew days to smell the egg smell u get when your cat goes. so check it out
