Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 02-05-2005, 09:27 PM
llaznthug llaznthug is offline
Transmission Help!!
2.05.05
What do cam gears and cam shaft do for horsepower and torque?? Any help will do!
Old 02-09-2005, 03:23 PM
Re: Transmission Help!!
Cam gears do not do much except reduce weight correct??
Any help or suggestions would be great!
Old 02-09-2005, 04:28 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
cam gears and cam shafts have nothing to do with your tranny.
Cam gears allow you to adjust your cam timing. Cam shafts give you different valve lift, duration and overlap depending on what cam you are using.
Empty Pockets Racing Member #1
Old 02-09-2005, 08:15 PM
wut exactly does cam timing do? and does variable valve time, such as VTEC, improve performance? if so, why??
Thanks
Old 02-24-2005, 12:40 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
vtec changes the cam profile of your car at a certain rpm, when that certain rpm is reached the vtec kicks in you get more power.http://auto.howstuffworks.com/question229.htm
Old 02-27-2005, 10:33 PM
2slowrex's Avatar
2slowrex 2slowrex is offline
nigg
