| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
2002 CR-V Pulling to the right
We just purchased a used 2002 Honday CR-V with 35,000 miles from a local dealer. According to Carfax, it was a one owner within our state. My wife totally loves her new CRV, but it is slightly pulling to the right. We have returned to dealer twice for alignment, put it still pulls. Even after nudging the wheel to the left on a long straight away, it will eventually head to the right. This is happening but under power and coasting. Don't know if dealer is not able (they are a Nissan dealer) to do the work or if we're just getting the run around. Was wondering if anyone was aware of a known problem with the CRV pulling to one side or the other and what solutions were taken to correct the problem. Any help or advice from other CRV owners would be greatly appreciated. THANKS!
Re: 2002 CR-V Pulling to the right
I'd take it to a wheel/tire shop to get it aligned. Have you checked the air pressure in the tires. An under inflated tire will make the car pull one direction or the other.
![]() Empty Pockets Racing Member #1 |
checked tire pressures?
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
Also when they do alignments, they usually do a front end alignment. It could be that the rear end is out of alignment and it is actually pushing to the right. But i would check the tire pressures first.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
Re: Re: 2002 CR-V Pulling to the right
Tire pressures are the first things that should be checked during a 2 or 4 wheel alignment. If that wasn't done that should be checked.
I'm thinking it's a tire issue, try crossing rotating the tires. Left to right Right to left and see what happens from there. Otherwise get to a Honda dealer before the factory warranty - 36,000 miles runs out, very unlikely it's a warranty issue but anything is possible. |
