Old 02-05-2005, 06:55 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Oil Pressure Sender Install
I know I posted about this before, and then posted a link on how to do it. But, when I go and try to install the sender unit today (FINALLY got around to changing my oil), I was totally lost. On the N/T, there is no little bolts around by the oild filter to install the sender. All there is is mounting bolts. Tried taking some out, just to make sure, and I was right. Had the splash shield out, so I was looking at the whole thing from a good angle. The instructions that I found showed 2 places to add a pressure sender and an oil temp sender, but nothing was there. Where the hell can I install the oil pressure sender? I got the gauge all installed, but it's limp . Anyway, where can I install it on a N/T ESi? Any help?
Thanks a million
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-05-2005, 09:01 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Oil Pressure Sender Install
you might need to buy a Y fitting to go into the stock oil pressure sender port then mount both pressure senders in it.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-07-2005, 01:28 PM
david-b's Avatar
Dave is THAT guy
Where is the stock oild pressure sender though? There is nothing looking like 1 around the oild filter. Theres nothing there at all.
75 Monte Carlo
