Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-05-2005, 06:26 PM
bcproductionsinc bcproductionsinc is offline
Send a message via AIM to bcproductionsinc Send a message via Yahoo to bcproductionsinc
Can't open hood!
Help please. I cant open my hood to service anything. Of course I tried the hood open cable and tried to pry it open while pullung the cable too. Anyone experience this.
1991 GMC Jimmy 4.3
Old 02-06-2005, 06:20 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Can't open hood!
Pull the lever, walk to the front, bump the front corner of the hood with your hand a few times. It should pop up....if it does oil the latch and you'll have no more problems.
Old 02-06-2005, 10:15 PM
msully63 msully63 is offline
1991 GMC Jimmy 4.3
I have a 1998 Jimmy and I was able to lift the hood up enough to loosen the the two 13mm bolts holding the latch to the front end. I then was able to get the hood up far enough to reach get the latch to open.
My problem was that the cone spring on the hood fell off so when I pulled the cable it wouldn't force up through the latch. Worse case is that you cut the cable so you can lift the hood completely and easily get at the latch assembly.
Changing the cable wasn't too bad once the parking brake was out of the way. I used a coat hanger taped to the old cable to help route the new cable.
Old 02-07-2005, 08:32 AM
Got my hood open everybody. Thanks. I just looked under the hood while my fiance was pulling on the cable and saw what it was supposed to do. So I just put a screwdriver in it and gave a push and she opened right up. It was closed to tightly I think.
Again, Thanks alot.
Old 02-07-2005, 09:30 AM
blazee's Avatar
Problem?
You should probably put some oil on it.
Old 02-07-2005, 11:01 AM
Yeah. I sprayed some lube on it. Works great now. Thanks to all.
