Old 02-05-2005, 06:03 PM
sachadesousa sachadesousa is offline
1995 wire and plug replacement
well it happens every year, i have to replace the plug wires because of wear and tear
this time i want to do it myslef instead of paying lotsa $$$ to get it done
can u ppl tell me how its done?
i suspect it needs to be raised, i just took a look at the engine and could only spot 2 plugs on the left side of the engine
i know where they are but i have to get some reliable jacks if i have to raise the beast to get to its heart
thanks alot my friends
Sacha De Sousa
Old 02-05-2005, 09:55 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 1995 wire and plug replacement
Here is a site I found on changing them (actually cuda found it for me but I will steal credit). http://maysvilleky.net/~gbeard/fourth-genFAQ/4_2aq.htm
Although I don't agree with having to remove the Y-pipe. As to get those bolt loose will probably be more of a chore than changing the plugs. I found it easier to get the number 7 from under the car. The number 2(requires removing the alternator) I had to get on the engine with my arm twisted behind my back to get to and number 8 you will need a swivel head wratchet to get out or you could find someone who is double jointed. Not easy job at all but you will save yourself at least a couple hundred dollars. Also wires you will have to be done from under the car and you will have a real hard time getting the on the opti cause of the waterpump being right there but its doable. Good luck.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
