Old 02-05-2005, 05:58 PM
bb2500hd bb2500hd is offline
Right rear brakes
The right rear brake keeps locking up when the brakes are applied.
I have replaced the rear drums and brake pads but the problem still exists.
Also the ABS and Brake lights came on and stayed on after the repairs.
Any ideas?
Thanks
Old 02-06-2005, 09:02 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Right rear brakes
usually drum brakes will lock up if there is excesive brake dust, gear oil contamination, weak return springs, self adjuster not working(bent), water contamination(plug missing, damaged backing plate/drum) brake fluid contamination. or something wasn't installed correctly. you should find out why those lights are on, most times abs just means a wheel speed sensor wire is broken but the brake light is more dangerous, it can come on if the fluid is low or if pressure is lost in half the system(leak)
i
Old 02-06-2005, 11:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Make sure the proper shoes are in place. One friction surface should be longer than the other. The smaller one should go to the front. If you see they're both the same size, pull the other drum off to make sure you didn't put the short ones on the left and the long ones on the right.
