Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-05-2005, 05:57 PM
zonk3939 zonk3939 is offline
98 Explorer Tranny problem?
Weirdest thing..My 4x4 selector never showed the Transfer case was in 4 low,but would signal it was in 4 high.It never seemed to matter until today.
I drove the truck about 130 miles one way today.When I got to my destination,I had to wait for someone for a few minutes.I decided to try to see if the Low Range light would come on if I shifted it into neutral and moved the selector into 4 low.Well,it didnt work,but heres what it seemed to do.
I shut the truck off and went inside for a few hours,when I came back to leave,the truck didnt want to shift out of what seemed like a very low set of gears..I could feel it shift 3 times,but it would then rev out to about 4500 rpms and onlly go 40-45 mph.The "O/d off " light would then blink on the dash.If I push the OD switch on the end of the gear selector in,you can feel the tranny shift down to a lower gear,(as though you took O/D off under normal circumstances).
Confused yet?
Coud it be the selector motor on the tranny? I dont hear it shift or any motor noise,as though it would be engaging,when I move the knob.
A local mechanic read a code that said something along the line of 4wd low selector fault..something worded like that,anyways.
Old 02-06-2005, 11:25 AM
OK..turnd out to be the selector motor for low/high on the transfer case.$446 bucks installed.Better than a new Tranny,I guess.
