Old 02-05-2005, 05:06 PM
Pimpdady753 Pimpdady753 is offline
Air Con. Pully
ok i herd if you take off the air conditioning compressor, or what ever it is called. you will free up some power. How hard is it to take it off, and do i have to get a new belt, a smaller one. a little insite please.
Old 02-06-2005, 08:10 AM
eillob's Avatar
eillob eillob is offline
Re: Air Con. Pully
You'll free up some I doubt you'll notice, the biggest benefit is that you will take a considerable amount of weight off of the front of the car. Its not hard to remove there are four bolts holding it on plus lines. If your using the AC replacement pulley and you still have your smog pump on you can run the stock belt. I don't use the pulley Im just running a smaller belt.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
