Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 02-05-2005, 04:03 PM
ps27 ps27 is offline
Shake/ rumble when I hit the brakes.
96 skylark 2.4l. When I hit the brakes at any speed over 30 the car shakes. This gets worse when at higher speeds. Brakes have all been replaced, still have prob. Car has new tires, struts, shoks. Any help would be appreciated.
Old 03-18-2005, 05:34 PM
Mr.Molasses Mr.Molasses is offline
Re: Shake/ rumble when I hit the brakes.
everything was replaced on the brakes? pads, rotors, calipers? how about the wheel bearings?
Old 05-18-2005, 04:53 AM
steve101 steve101 is offline
possible fix
in my experience shaking a shuddering when applying the brakes means the rotors are warped and either need to be cut or replaced. it is not uncommon for the rotors to be warped fresh out of the box
Old 05-22-2005, 07:53 PM
beau078418 beau078418 is offline
Is it a shake or a shimmy? When you did your front brakes did you look at the rotors? I'm sure you did but, if your rotors wasn't replaced I might suspect a warped rotor. On time on my Chevy Tahoe I was going real fast and had to stand on the brakes to stop to avoid a wreck. I heated up the RH Front rotor real hot and it warped. Thus from then on everytime I applied my brakes I would get a shimmy. I replaced the rotors and it went away. Just a thought....
Beau
Old 12-26-2005, 08:43 PM
Zarder Zarder is offline
skylark shakes
Try shifting into neutral before braking. If that stops it, your trans is failing to disengage the lockup torque converter. One choice then is to clip that wire going to trans.
