Old 02-05-2005, 02:43 PM
DSMNerd6889 DSMNerd6889 is offline
2nd gen motor in 1st gen car swap.
I know you must all think I'm retarded, but I have a perfectly good 2g 7 bolt motor in my TSi FWD and I just found a local 1g GSX in good condition for super cheap. I was wanting to know how tough it would be to get my 2g motor in the 1g GSX. I figure my clutch and pressure plate might be the same, but the flywheel would be different. It's a 99 GSX motor that I have, so I'm also guess the CAS would be the same too? Anyways... Any thoughts or comments would be appreciated.
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 02-05-2005, 03:13 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: 2nd gen motor in 1st gen car swap.
Whats wrong with the motor in the GSX? It wouldnt really be worth the time or money... Yes its possible, but its gunna be a pain and a waste!
Old 02-05-2005, 04:44 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Yeah man, that really doesn't make too much sense to me at all. Please let us know why you would want to do that.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-05-2005, 07:14 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
it would make more sence to install the 2g 4bolt rear end and 2g tranny into the 1g insted.
DSM geek
Old 02-06-2005, 12:44 AM
The gsx I was looking at was just the shell and tranny, no motor. That's why. Also, my 2g isn't AWD.
1990 GSX
Old 02-06-2005, 12:48 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Ok, but the question still is, why? The 1g motor is stronger than the 2g and WAY WAY WAY less prone to crankwalk, maybe 1 in 10000. Putting the 2g motor in a 1g is like putting a honda motor in a dsm, it's a bad idea!!
95 Talon TSI AWD
97 Eclipse GST
Old 02-06-2005, 12:49 AM
Vtec95Civic Vtec95Civic is offline
If the 1g is a shell I would do it, for the AWD. I'd say 1 g AWD with a 2g motors is better than a FWD 2g.
Old 02-06-2005, 01:23 AM
kjewer1 kjewer1 is offline
AF - Advisor
It isnt possible. The 1g's motor mounts are part of the block. The 2g motor wont have them. 2Gs mounts are on the tranny, which is why we can use the 1g blocks
Edit> Second guessing myself. I would check to see if the bosses for the mounts are there, sometimes they cast in useless shit like that, or perhaps it was used in some random obsure car the motor was used in, etc. But don't hold your breath.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
