Old 02-05-2005, 01:43 PM
reddragon77 reddragon77 is offline
Unhappy Anyone have vibration around 20mph, bearing insulators ???
I have a 92 vr4 and car feels like its going to shake off the chassis at 20mph it then clears up and comes back when i am c???+??PChecked all easy solutions, anyone have this problem before? i dont want to get handed a fat one at the dealership, that we all know probley is as much in the dark as I am thanks. Could it be the bearing insulators on the driveshaft ???????
Old 02-05-2005, 01:45 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Anyone have vibration around 20mph
Ball joints or allignment maybe? What are the easy things you checked out?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-05-2005, 02:35 PM
Originally Posted by reddragon77
I have a 92 vr4 and car feels like its going to shake off the chassis at 20mph it then clears up and comes back when i am comming 2 a stop. Checked all easy solutions, anyone have this problem before? i dont want to get handed a fat one at the dealership, that we all know probley is as much in the dark as I am thanks.
I put new tires on they said my tie rod was going bad but did not tell me that untile the car was on the ground.. im thinking somthing with the driveshaft at lower speeds somthing is binding up and with the speed the spinning of the drive shat actually balances it out. do you know of any clamps that could be replaced
Old 02-05-2005, 05:03 PM
Igovert500's Avatar
blue + red light magnet
Driveshaft u-joints, tie rods, alignment, wheel bearings, tires need to be balanced, warped rotor...tons of things could cause vibration.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-05-2005, 09:21 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
do you feel the vibration only when accelerating? how bout when braking? when braking hard? or just braking lightly? please give us more specifics.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-05-2005, 09:29 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
if it does it when accelerating, it may be a driveshaft vibration. probably the u-joints...
ZedEx Crew Member #4
Old 02-06-2005, 10:49 AM
Igovert500's Avatar
This might help with the u-joints:
http://www.3si.org/forum/showthread.php?t=254949
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-06-2005, 02:42 PM
Boosted1 Boosted1 is offline
Definitely the U-joints. Chrysler/Mitsu wants $250/piece (CAD) for them here. Ouch. For that price, if the car doesn't sell "as-is", I will just buy an aluminum or CF driveshaft.
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 02-06-2005, 04:12 PM
Re: Re: Anyone have vibration around 20mph
I would like to thank all of you for your help, I know all of you as I think of our cars as one of a kind. However very expensive to maintain and fix, well i think its worth it. Im putting the car up and my mech will take care of it for 100.00 which is a cfs. He doing its so cheap because he replaced the motor with a brand new crate motor and a new tranfer case( all the insides), the way I see it I spent 8,000 on this already and he should have seen the problem when it was in the air and im swapping a furnace for the cfs, I made out pretty good I think.
Old 02-08-2005, 08:25 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
I had that prob on my 92 VR4... so i took a look at my drive line and noticed i need to replace my Carrier bearings because they where geting worn out... if thats the case, the only place to get them is the dealer... i think i payed around $145 for them... what i did is took them home and got some silicone and filled them full of silicone to enhance life time on them. then you have to take your drive shaft off and take it to a machine shop to get them removed and replaced because they are pressed on...
Upgrades... To many to list...
