Old 02-05-2005, 01:15 PM
rokoco rokoco is offline
HELP:rear main seal
Can anyone give me a clue as to how tough it will be to replace the rear main seal in my '91 Metro Conv.? Like does the tranny need to come out with the engine? Anything else, tricks, etc. will be greatly appreciated!!!
Old 02-05-2005, 06:19 PM
Tominator2000 Tominator2000 is offline
Pull the motor without the tranny.
No need to remove the hood. Remove the alternator, starter, front pulley and just unbolt the complete intake manifold and tie it up out of the way. That saves you from rerouting all the hoses and wires. Remove bolts to exgaust and let it hang. You will remove various other sensor wires and hoses that are obvious.
Using an engine hoist to support the motor, remove the motor mounts and engine to tranny bolts. Remember to support the front of the transmission housing so it remains level.
Should take you 4 to 5 hours if you take time out for a beer or two. It is VERY important to start WITHOUT the beer beforehand and to regulate severly that intake of said beer until job is mostly finished.
Old 02-05-2005, 08:14 PM
geozukigti geozukigti is offline
It'd be a LOT easier just to pull the trans. Support the motor, pull the trans, remove the clutch, and the seal is right there.
Old 02-05-2005, 10:53 PM
LOL! You indeed know a ton more than I do about these cars.
You did not include some steps though....Remove wheels, calipers and take off the axle hub nut. Can you then swing the strut and brake assembly out of the way to pull the axles? Some cars you can and others you cannot.
I, for one, am much more comfortable not messing with the suspension on an old car as seals, constant velocity joints and brake hardware tend not to go together as easy as they came apart without some replacement parts at hand.
After pulling the motor one time, bet I can do it in two hours or less now.
And THEN I can work on it on a engine stand!
Easier on my back.
