Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 02-05-2005, 11:45 AM
runner97 runner97 is offline
rust colored specks on finish
My '97 Runner (desert dune color) develops tiny pin head sized blemishes on the painted finish during the winter that look like tiny rust spots. However, in spring when I wax the car, these blemishes are easily removed. Anyone else experience this with a light colored 4runner? Is this rust on top of the clear coat?
Old 02-05-2005, 08:25 PM
stockerjo stockerjo is offline
Fly/bug sh*t.
Old 02-05-2005, 11:44 PM
mjshort18 mjshort18 is offline
Re: rust colored specks on finish
you should try waxing your car more offen. try doing it right before winter and then you may not have this problem. really you should wax your car every month because this is the longest the wax will last.
Old 02-08-2005, 09:49 AM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
This is fairly normal on light colored paint jobs. The metals in the air sit on top of the clear coat and make a small rust spot. As you have noticed they are easily removed. Just don't let it sit too long on the clear coat as it can eventually eat through the clear coat. Just maintain the paint with a good waxing as needed. Good luck!
WAR UTAH!!
Old 02-08-2005, 10:03 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Re: Re: rust colored specks on finish
Somewhere in the truck finish's history someone was using a metal grinder, the hot specks of steel embedded in the paint, good advice aside of repainting has already been given:
Good Luck
