Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 02-05-2005, 10:34 AM
jorgerom jorgerom is offline
MY CAR DOES A "BUZZING" SOUND?
My Car Does A Buzzing Sound When I'm Going About 10 Miles Per Hour To Whatever Higher Speed I Go. Could It Be The Transmission. The Sound Seems To Come From The Back Wheels. Any Have Any Idea Of What I Should Look For? Any Help Would Greatly Be Appreciated.
Old 02-07-2005, 01:19 AM
series8217 series8217 is offline
Re: MY CAR DOES A
Could be out of balance tires. Have you had them balanced recently? You could try rotating them front to back (only do this temporarily on an 88 due to staggered sizes) to see if there is any change.
Does it happen when in neutral also? What about with the clutch pedal pressed in (if its a manual tranny)?
-Steven
Old 02-07-2005, 08:05 PM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: MY CAR DOES A "BUZZING" SOUND?
It could be the fuel pump which is in the gas tank under the center console.
Old 02-08-2005, 05:08 PM
Re: Re: MY CAR DOES A
-Steven
IT HAPPENS WHEN IT'S RUNNING AND I PUT IT IN NEUTRAL. IS THERE SOME TYPE OF BEARING THAT COULD BE WORN OUT?
Old 02-09-2005, 07:40 PM
coop8267's Avatar
coop8267 coop8267 is offline
they only buzzing ive ever heard from my car is the fuel pump but you can hear that even befre you crank the car. like when you turn the key where everything comes on. it does it for a few seconds to prime it just incase fuel drained out of the pump.
