It sounds like you need the temp valve actuator. My invoice from the dealer just says 16141822...actuator. No real help there. The inlet valve is directly behind the blower motor on the inside of the car and allows air from the blower to enter the HVAC box. The replacement of the temp actuator usually requires removal of the dash. Since this is not a simple job, you may want to go to a dealer to get the ECC scanned for codes to ensure that this is definately the problem.
When I bought my replacement, the dealer needed the last 6 digits of the VIN because there were two possibilities. The above part number might not be the same for your car.
TIP: I paid $58.94 at the dealer for mine because I needed it right away. If you can wait a couple of days and order it from
www.gmpartsdirect.com, you'll save some $$$$
GM PART # 16141822
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $58.38
OUR PRICE: $29.18
DESCRIPTION: ACTUATOR
They can help you determine the correct part number, usually via email.
