Old 02-05-2005, 09:27 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
clutch assembly on ac compressor
yeah i beleive the bearings on my clutch assebly is going out (very anoying noise)... and i can only find the assembly already together with the ac compressor for like 800 bucks... so i though mabey ill just get a smaller belt leave the compressor off and just run the altinator to the underdrive... does anyone know if that will clear?
Upgrades... To many to list...
Old 02-05-2005, 08:45 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: clutch assembly on ac compressor
hey man. you might try napa, but from experience i know that A/C compressor clutches aren't cheap. around 250 at least. ur best bet is to look at salvage yards. a great resource is www.car-part.com. its a database of all the salvage/junk yards in the nation. i did a few quick searches in Tx (i see you're from Bridgeport...i'm in Dallas) and i couldn't find JUST the compressor clutch. but when i searched for A/C compressor in TX, i got a bunch of hits. ur best bet from there is jsut to call around and see if they have the compressor clutch and if they'd be willing to sell it separately.
that's a lot easier than getting a custom belt for just the alternator. however, i'm sure you'd free up some hp if you did just run the custom belt with no A/C.
let me know how it turns out.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-05-2005, 08:59 PM
92VR4Red's Avatar
yeah thats was what i was thinking... little hp gain really i can probaly messure around the altinator pully, tensioner, and idler pully with a vinyl messuring tape and run up to autozone and get a belt... they should have one that size...
Old 02-05-2005, 09:09 PM
Linebckr49's Avatar
ya, its worth a try. and if the belt works and all, you COULD rip out all ur AC stuff. probably save around 50 lbs b/c that compressor is pretty heavy. BUT, think before you do it. b/c if you end up finding a compressor clutch and wanna install it and put the A/C belt back on, then you might have to charge the system again...and that's expensive b/c our cars use R-12...the old stuff. most all new cars use R-134 which is more environmentally friendly (for you Thourun!).
93 3000GT base
Old 02-05-2005, 09:24 PM
92VR4Red's Avatar
yeah true... mabey i should just take it to mitsu and see what they ahve to say...
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Meh, I think chemical polutants are overhyped, the real bad stuff is polution of the ocean and C02 emissions. Ohh yea and saving the forests would be cool too!
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-05-2005, 09:27 PM
92VR4Red's Avatar
lol my car has no emissions... i took all that crap off like the char chamber and what not... and i have no catalic converters...
im all about to echosystem. lol
Old 02-05-2005, 09:46 PM
Thourun's Avatar
I honestly don't think that the tens of thousands of car enthusiasts withought cats make a difference since like I said, all combustion makes C02 which is the big problem in my book. The aircraft industry dosent have to use cats and they can even use leaded gas still which is a real problem... but they're special. Not having cats just makes more ground level smog and ozone which mostly affects people, and I don't care much about most people lol.
1995 3000GT VR-4
Old 02-05-2005, 09:55 PM
Linebckr49's Avatar
Tad, you don't have to be "not against cats" to be accepted here in a cars forum. we love you man. you can rag on us as long and as much as you want. we know you're right and our only excuse is "we want more power and this is the cheap way to do it!". so don't let up, keep at it. every bit helps, although probably jets and factories do cause the majority of the CO2.
93 3000GT base
Old 02-05-2005, 10:00 PM
92VR4Red's Avatar
i dont think just little old me and cause much damage... lol but i bet their is alot of people saying that too :P
think of it this way... if your a inviromentalist then you shouldnt even have a car... just get a bicycle
Old 02-05-2005, 10:05 PM
Thourun's Avatar
Well thats the thing, every bit does help but I think its worth it for us lol. And I think jets run on kerosene, its the props that run on super high octaine gas.
About the environmentalist thing, I'd rather study it than protest on behalf of it lol.
1995 3000GT VR-4
