interior lights/door ajar
I often cannot get my door ajar/interior lights to go out on 99 expo. is there a set of contacts that need clean/adjust? this seems to be a common problem on ford had the same problem on 99 f-250.
thanks, doug |
open all the doors, including the rear hatch, and spray wd-40 into the latch mechanisms, then follow up with a coating of silicon spray, this should "fix" the problem.
worked for me and others hth Rick, Ore |
Re: interior lights/door ajar
I agreed with bearcat329 . wd-40 work for me.
Try it is cheap and easy to do. Later... Al |
worked like a charm
thanks, used wd-40 and it worked like a charm. I have been putting up with that for months. thanks again for your assistance
Re: worked like a charm
Good Luck! |
Re: Re: worked like a charm
Hey guys, I have the same problem with my front passenger door. For a couple of years I've dealt with it. I just joined earlier today and already had good results. Thanks for the good info.
