Old 02-04-2005, 11:07 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
ECU Code Help (PR4?)
so tonight my car started acting up, start to kinda mis fire up at 4 grand then it was fine after that, took it out for a rip up and down the road quickly by my buddys house, pull it into the driveway and the check engine light comes on.....
lift up the carpet and it flashes 4 times slowly, like the light stayed on for a second each flash, then it flashed 3 times rapidly right after and kept doing the same 4 slow, 3 fast pattern..... i'm running a 90 teg GS ECU (think its the PR4) what is the problem with my car? lol
but it was weird, drove it home and it was fine?!? i dont get it
Old 02-05-2005, 11:21 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: ECU Code Help (PR4?)
fuel pressure is either too high or too low....
do you have an aftermarket fuel pressure regulator or something that that u are using to turn up the pressure? If not, there is either something clogged in your fuel system namely the lines, or filter, fuel rail, etc.
I think ur ecu will start throwing the code after you turn ur car over 48 psi at WOT...
I'm running 55 psi at WOT and i run with the code all day...
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-05-2005, 01:29 PM
1PhatCX's Avatar
i dunno, it only happens at 4 grand, started again today
picked up a civic and teg fuel filter, gonna try the teg first and see if it fixes the problem. and no i have the stock pressure regulator, but its working fine
Old 02-07-2005, 10:19 AM
1PhatCX's Avatar
well i threw in a new fuel filter yesterday for a 90 - 92 B18 Teg but it didnt seem to help, so it wasnt a clogged filter, i'm gonna try and throw my PM6 back in and see if it fixes the problem
anymore ideas let me know
